Hi All, this question regards an issue I'm having with the Database Connectivity Toolkit, 1.0.1.
I'm retreiving a record (a bunch of records actually) from a Jet database and creating a 2-D table that SHOULD be sorted by time, as that is how the data has been collected. In short runs the data is time-linear.
However, more recent runs with longer data sets is returning data that is being reported in scattered out-of-sequence blocks. I know, that's not very clear.
I'm collected data points (from a 3-rd party hardware) that includes index #s, timestamps, etc for each data point. They are saved in a Jet database.
When I open that database with Access and review the records as a 2-D array, the data is sorted with respect to time.
However, when I use the DB Toolkit to retrieve the same data, it looks exactly the same except it looks like somebody imported it into Excel, randomly selected a continguous block of rows, then cut-and-pasted the data elsewhere. The shifted data blocks look random in both size and movement.
Because all the data is there and not corrupted, I can fix the problem by doing an Excel 2-D data sort based on the timestamp, but I shouldn't have to do this, should I? I'm aware that 'sorted' data is not neccessarily a condition of the database data, but Access seems to find it that way. Perhaps there is an SQL command that will fix the sorting problem? I know nothing about databases or SQL language.
thanks,
Matt
