Database Query Error -2147467259 ADO Error: 0x80004005
Can you post a sample screen capture with the schema attached?
Glad to answer questions. Thanks for any KUDOS or marked solutions 😉
Message 11 of 24
(2,430 Views)
I don't know what a database schema is.  Google helped a bit but still am unsure what you are asking.
Message 12 of 24
(2,416 Views)
Sorry about that.
@rolfk
Can you post an example with the database schema attached.
Message 13 of 24
(2,410 Views)
This might help you and others on what not to use: Access 2007 Reserved Words
Message 14 of 24
(2,393 Views)
@PatrickLye wrote:
Sorry about that.
@rolfk
Despite the name that could make you expect something else, a schema in database talk is not a graphical drawing of any kind but simply an object container that usually contains tables and stored procedures. There is usually a default schema such as "dbo" for MS SQL Server. A fully qualified column name therefore is specified as {<schema name>].[<table name>].[<column name>]  While many (semi-)professional databases don't use any other than the default schema and in that case it is really redundant to specify, for larger databases use of multiple schemas within a database is very common and then it gets important to specify the schema name too to disambiguate the names. There could be a table "Customer" with column "First Name" and otheres in a schema called "Sales" and another schema called "Support".
Rolf Kalbermatter
My Blog
Message 15 of 24
(2,382 Views)
Yes I understand schema. All of mine in SQL server, so far, use dbo. I was just wondering about the SQL string you're using including the schema. I'll play with this a bit.
Message 16 of 24
(2,376 Views)
I see, I misunderstood your use of attached. :-). Because the schema name is prepended I thought you expected some attachment to the post with a drawing or something like that.
The complete identifier would for instance look like this:
[dbo].[Customer].[First Name]
Strictly speaking only
Customer.[First Name]
is required but bracketing every identifier isn't that much more work and saves me the worry about if the square brackets are necessary or not.
Rolf Kalbermatter
My Blog
Message 17 of 24
(2,365 Views)
Hi all,
I have the same error. But it only happens when I run two test consoles at the same time. Any suggestions would be greatly appreciated! Thank you!
Jun
Message 18 of 24
(2,186 Views)
How about don't run two consoles?  Lots more information is going to be needed to get much help.  Look at my first post.  I include complete source code, showing examples of where it worked, and where it didn't, I mentioned what things I tried, and what things I searched for previously, along with details about my database size.  You gave very little information, so you will get very little help.  Since it doesn't sound like the two issues are related I'd suggest making a new thread where you provide this information.
Message 19 of 24
(2,167 Views)
The error message is very clear. There is a deadlock condition the can't clear on its own. If you only have one process active and interacting with the DB, you obviously can't have a deadlock. A deadlock is when two processes mutually block each other from completing. For example A can't finish until B is done, but B can't finish until A is done.
Why the deadlock? Well it could be due to the way you LabVIEW application is written, or it could be the way the database is structured, or it could be some other code running in the database (stored procedure, trigger, etc), or it could be some other reason -- which brings us back to Brian's suggestions.
1. Start a new thread
2. Provide details
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 20 of 24
(2,150 Views)
