You don't need any liscense. What you do need is to make sure you include DS support in your installer (you can select this option when you build your application) and you have to have the DS server running for it to function, so you need to do this either from your operating system or from within your code (there are functions which allow you to check and control the DS status).
___________________
Try to take over the world!
