03-10-2009 06:56 PM
I have PCI-6221 and controlling it with LabVIEW 8.2.1. I am measuring a voltage with an express VI; I set the Acquisition mode to N Samples and 1000 samples at rate to 250kS/s. I am only achieving a 163 S/s rate. Is there way to increase the sample rate? Or am I just reading anaverage of values between each increment of time? i.e. since the board is reading at 250kS/s and since I am reading at 163 I would be missing1533 samples. Are my readings just an average of 1533 samples? If so how can I change it so I just read the value of the sample at that given time? Also I am using a while loop; is there a better way to run a program to increase speed? Finally, since the my daq board has a sampling rate of 250S/s does this limit the speed at which my computer exicutes programs?
Thank You
03-10-2009 09:33 PM
