Data Logging
I am working on data logging ,and facing some minute problem with it.
when data is saved to the text file it contains additional 00000  after the actual decimal value which should not be there according to the logic.
I am attaching a vi as well as the snapshot of the text file with the problem  and have circled the extra zero's in it.
please help me with the solution.
shivkant paswan
(2,444 Views)
That is because you have configured as float and by default it takes the system decimal (6). Try changing it to decimal and see what happens.
(2,438 Views)
If you are using decimal number, you should write %d instead of %f.
PBP
Labview 6.1 - 2019
(2,426 Views)
hey ,
thanks guys i got it .
infact  i had tried this earlier but dont know why i was not getting the desired result.
but now its working fine.
Thanks a lot .
(2,414 Views)
