Data Dashboard Waveform Indicator with Multiple Plots
I have a Waveform Chart with multiple plots on my running main VI.
I am using the Data Dashboard 2.2.1 Application on my Ipad to want to monitor the Waveform Chart of my Running Application.  I have placed a Waveform Indicator on my Ipad, and also linked it with my Waveform Chart variable.  I can not play my Data Dashboard App because it shows can't connect to the Server.  I noticed that it is because of the Multiple plots being plotted on my Waveform chart.
I could only play the Data Dashboard App when it is just a single plot linked to an indicator on the App.
My question is if it is possible to have a Waveform Chart indicator on a Data Dashboard that has multiple plots being plotted, and not just a single plot, and how do I configure it?
Thanks.
(3,464 Views)
Source: http://www.ni.com/white-paper/14033/en/#toc2
2. Multi-plot Graphs
2D array of numerics and points are now supported allowing for multi-plot chart and graphs. This will allow multiple data sets to be viewed on one UI element instead of needing multiple ones.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,441 Views)
Hi Fitzsimons
Thanks for your response.
(3,436 Views)
Accepted by Tebefia
Click Kudos and select as accepted answer.  You are welcome.
Matthew Fitzsimons
(3,430 Views)
I see that is supported, but how is it coded to be done?
There don't seem to be sufficient examples/tutorials to do this?
(3,185 Views)
Hey Oley_Mich,
My name is Henry and I am an applications engineer at National Insturments. Have taken a look at the Data Dashboard for LabVIEW tutorial at the following link, http://www.ni.com/tutorial/13757/en/. That could be a good place to start with building a Data Dashboard interface.
Additionally, the following white paper, http://www.ni.com/white-paper/14689/en/, provides an explanation of how you can integrate the Data Dashboard with existing LabVIEW applications.
Best,
hfar2
(3,154 Views)
Ich kann bisher nur einfache Variable (single, double) mit DataDashboard darstellen.
Wie kann ich bei Chart 2..3 Kurven darstellen??
Bei der Umgebungsvariablen kann ich nur single / double /Array... vorwählen.
Für Ihre Antwort herzlichen Dank
mfg. Kaufmann
(1,616 Views)
