05-01-2006 11:11 AM
This little-known feature of LabVIEW 8.0 was mentioned in one of the threads of the LabVIEW Developers Feature Brainstorming forum. You can use Ctrl-Tab on your keyboard to cycle through all of the open LabVIEW windows on your system. This can be a lot faster than using the Alt-Tab combination on Windows, which, as you probably know, cycles through all open windows of all applications on your system.
-D
P.S. - Check out past nuggets here.
05-01-2006 03:19 PM
I very often use this CTRL + Tab in other applications (CorelDRAW, Word, etc.), but I never try use it in LabVIEW.
Thank you for this tip, I will be very useful.
bogdani
05-05-2006 11:51 AM
05-05-2006 12:39 PM
