03-20-2006 10:55 AM
03-20-2006 12:29 PM
That is a good tip. I have been using that since LV 6.1 although it probably existed before then. You can also use that same feature in the icon editor.
Keep the tips coming.
03-20-2006 03:04 PM
03-20-2006 03:29 PM
Good call, this is a bug in the Properties dialog. There is no reason you shouldn't be able to select a Transparent color there. I have filed a bug report on this issue (reference #3VJED2F2), so we should see it fixed in a future LabVIEW version.
-D
03-23-2006 06:59 PM
03-24-2006 03:55 AM
hi All,
I'd like to share one more Tool to interchange the wires without deleting & rewiring, in two terminal icons like, Addition, Division, etc. Keep the wiring tool in one of the terminals & press the control key. u should be able to see a new tool like "8", with an arrow tip.Now click the mouse & the two terminals will get interchanged automatically. So easy way to rewire without deleting them. Just thought of sharing with others...
Partha.
03-24-2006 09:56 AM
