01-02-2014 03:32 PM - edited 01-02-2014 03:33 PM
ad. 1a) Yes, I restarted LV after editing INI.
ad. 1b) Yes, I saved INI after editing it.
ad. 1c) Yes, I have LV 13, splash screen says so.
ad. 2) Windows 7.
ad. 3) I tried on block diagram and front panel free labels.
ad. 4) When I edit text (in free label) and e.g. highlight fragment of text and then use Ctrl-B, selected text is changed into "b", just like there was no Ctrl. I tried many ways. When I edit text and e.g. highlith fragment of text and then use Ctrl-B, selected text is chaned into "b", just like there were no Ctrl.
ad. 5) Is there any way to back up INI? I don't have "oryginal".
01-02-2014 03:38 PM
You can just rename your INI file "labview.bak", then make a new one (or copy the old one and delete all the tokens in it).
One other thought...does the Ctrl-B shortcut work for removing broken wires? Add some broken wires on your diagram and press Ctrl-B...do they go away? If not, then your Remove Broken Wires shortcut has changed, and QuickBold won't work. You can go into Tools > Options > Menu Shortcuts to see what shortcut is assigned to Remove Broken Wires:
01-02-2014 03:45 PM
Erase the contents of LabVIEW.ini. Launch LabVIEW. You'll have a clean slate of default tokens.
Next apply all your nice toys via Tools>>Options
Save a copy of the darn thing in a safe place!
Then go build yourself a nice exe from a vi to file copy LabVIEW.ini to your safe place and put a really interesting ico in the project. Make sure there is a copy of that super-cute shortcut on your desktop- (so you'll click it often)
01-02-2014 05:13 PM - edited 01-02-2014 05:17 PM
I have F2 assigned to Remove Broken Wires shortcut, and thats the problem
So basicly shortcut for Bold and Remove Broken Wires is the same, OK, now everything is fine.
Jeff, what's the point to copy my .ini to safe place all the time?
01-03-2014 07:19 AM
I keep a backup for fresh installs. I'm trying to get everybody in my group to use the same settings and shortcuts and what not. It is very easy to do if you have a backup copy of your ini file and then just copy it over with a new install.
It's also good to keep around in case you messed something up in your system. Replacing the ini back to a good setting state could save you lots of time.
01-03-2014 08:02 AM - edited 01-03-2014 08:07 AM
Pinned items on the Getting started window and recient history are in the ini. Loosing all your pinned items can be a bummer.
Don't do that to them, please. just write a login script to pull their ini off the network. Trust me that has saved life and limb in a diverse group of users. Unless you want to work with either A) a troup of "Timbots" or B) lead a group of developers that harbor resentments because they are sure they could be more productive but, the concensus was.... Their ini can be very personal.
05-16-2018 06:14 AM
Wondering, that it took 5 years to finally make it as really part of LabVIEW, for LabVIEW 2018 release...
