08-13-2008 01:06 AM
08-13-2008 09:10 AM
08-28-2008 02:57 PM
VI is going to come in VERY handy, Thanks!
08-28-2008 03:00 PM
Darren,
could you add the LabVIEW Dialog context as well
(I try debugging some IDE extensions)
Ton
08-28-2008 03:12 PM
The utility I posted will parse the user's project context(s) and the Main Application Instance. I cannot post a utility that will go through private contexts as well.
-D
10-28-2008 01:07 AM
See my post if you just want to change a modal dialog back to default - rather than abort.... I was inspired by this idea.
10-28-2008 04:30 AM
12-19-2008 07:34 AM
We appreciate for the efforts on "Abort VI.vi", recently I faced a problem where the "Statechart - Edit Triggers and Groups" window stops working and we could not close VI's. The alternative is to end the task from windows.The Abort VI.vi also could not stop this.
Manish Soni
12-19-2008 09:14 AM
ManishSoni wrote:We appreciate for the efforts on "Abort VI.vi", recently I faced a problem where the "Statechart - Edit Triggers and Groups" window stops working and we could not close VI's. The alternative is to end the task from windows.The Abort VI.vi also could not stop this.
Manish Soni
If you can reproduce this problem, please let us know. We would be eager to investigate it.
02-16-2009 02:39 PM - edited 02-16-2009 02:40 PM
Here is an unlocked version that only searches the current application instance.. I believe it was created by Dan Gilmore and offered on info-labview. This version will search for all the modal vis and give a menu to close.
I always keep a version in my Dock to get out of self inflicted problems!!
Enjoy, and modify away.
-Scott
Stupid Freaking Lithium, doesn't allow adding VIs as attachments. Sheesh.
Here it is as a zip file. I hear that works sometimes.
