10-14-2014 12:05 PM
Quick question that I'm fairly sure I know the answer to...
Short version: I have old hardware that uses IVI type drivers, and don't want to rewrite the acquisition routines when I upgrade the hardware. Is it possible to configure NI MAX to work with IVI type drivers in such a way that I can control the hardware within LabVIEW using DAQmx?
10-14-2014 12:12 PM
10-14-2014 01:20 PM - edited 10-14-2014 01:21 PM
I wanted the reverse. I want to see if MAX / DAQmx will access IVI type drivers (as basically a wrapper) so that when I upgrade I don't have to rewrite the acquisition routine to work with the new NI DAQ hardware.
Edit: Clarity
10-14-2014 02:27 PM
