04-21-2016 04:40 PM - edited 04-21-2016 04:45 PM
I am using LV2015 with sbRIO-9651. I have used the sbRIO CLIP Generator and enabled Serial3, and assigned the TX and RX data lines, and the DTR and DSR modem signals to physical pins, and set TX and DTR to output mode and RX and DSR to input mode.
I have a simple Realtime test .vi that uses this serial port. The test code (open port, write string, quit) runs OK if I select flow control = "NONE" in the VISA Configure block. However when I select flow control "DTR/DSR" I get the result "Error -1073807330 Property Node (arg 😎 in VISA Configure Serial Port ". Opening VISA Configure Serial Port (Instr).vi it looks like (arg 😎 is the Serial Settings:Flow Control. I don't know what is wrong. Are there any code examples I can look at that use DTR/DSR flow control?
04-22-2016 06:40 PM
You might want to try out the 'Serial Port Monitor' example VI in LabVIEW to see if you are able to manually manipulate and check the state of the lines.
08-18-2017 04:30 PM
We had this come up via another channel. Documenting it here in case others run into it:
