08-12-2006 08:40 AM
08-14-2006 02:09 PM
Hi Aviram,
You should be able to trigger off the events when both Hi Hi and Hi are enabled. To do this you would have to monitor the alarm area or url of the Event to determine which alarm triggered the Event. I have attached and example project that show a possible way to do this. You will have to change the shared variables to your machine and the case structure inside the Event Structure but it should work for you as well.
Looking to help,
Steve B.
08-21-2006 02:37 AM
