DETT: Set Cursor (Cursor ID) and Set Cursor (Icon Pict) VI Reference Leak
Using LV 2011 and the Desktop Execution Trace Toolkit to analyze my application, it has identified a reference link in the 2 above stated VIs. It's not a huge deal but is there any possibility I'm missing something here? Whether I use them individually or as subVIs in the Set and Unset Busy Icon VIs, it always report a reference leak. The block diagram is locked so I'm guessing there is not much I can do to correct it, but I just wanted to ask. Is this fixed in later versions? I am not calling this VI continually in a loop or anything, but I do use it quite a bit as my app is pretty user interface intensive.
Erin
(2,548 Views)
Same behavior in LV2014... I am also wondering if this could be something that i should consider... Any idea?
(2,214 Views)
Same behavior in LV 2017. I found a KB.
There is a workaround but I don't know the target date to be fixed.
Reference Leak When Changing Cursor Appearance in LabVIEW
Certified LabVIEW Developer
GCentral
(2,118 Views)
