02-20-2017 07:58 AM
Good day,
I have updated from labSQL to Database Connectivity Toolkit in labVIEW 2016 for one major centralized MSAccessDB, via ODBC (or MSAccess2007), an ohter MSAccessDB still accessed with labSQL (ADO-ODBC).
This major database must be accessed from 3 PCs, running the same labVIEW code + I simulated a semaphore to lock with an extra MSAccessDB (exclusive access).
Sometime, now, with lv2016 Database Connectivity toolkit (NI_Database_API.lvlib:DB Tools Execute Query), I assume no error appears (but If I have the opportunity, I will add general error handler immediately after the Execute Query to be sure) and we see that sometimes, the MSAccessDB is not updated!!
Can this be caused by using MSAccessDBEngine 2007 (for locking with extra dummy MSAccessDB + minor other logging DB) together with this Database Connectivity Toolkit ?
All on MSWindows7.
Kdc
02-20-2017 08:57 AM
There are a number of things that could go wrong but unfortunately, without seeing your code, we can only guess. Please share a code snippet.
Why did you choose Access for your dB? MSSQL Express is available for free. MySQL, the next best choice, is also available for free. Neither of these dB programs have limitations on concurrent connections.
02-21-2017 12:10 AM
We are indeed thinking about porting to MSSQLServer or MySQL. But almost everyone is familiar with MSAccess. And some databases of us are no flat table, but exists of subtables as well.
