04-04-2014 08:48 AM
1) my wait is 3 sec
2) when the wait is enabled , the sampling indeed occur at lower rate.
3) when hitting stop, i see no error messages
04-04-2014 09:14 AM
OK I'll jump in.
You never set the
So it remains at the default 100. You can't get "is late"=True until the 101st sample. Period! (Am I really the only one who ever read the manual on that?)
04-04-2014 09:21 AM
Tried that allready.
I pass the 101 iterration in 5 seconds if i set the rate to 20 hz.
it doesn't solve the problem.
try it yourself !
04-04-2014 09:29 AM - edited 04-04-2014 09:37 AM
try it yourself !
Not the 101st iteration(Sample clock). The 101st acquired sample. The first 100 samples cannot be late. you need 5 minutes to acquire 100 samples.
Try reading the help file
And don't forget to read the caveats like: What certain types of applications NI recommends the use of that function in. Unless you have one of these- and I doubt you do- You are missapplying the function anyhow!
04-05-2014 05:26 AM
At 20 sample/s it's only 5s for 100 samples or am I missing something? I can't see anything wrong with the code- it's pretty much identical to the code in the white paper.
Is the problem sorted or still an issue?
04-05-2014 03:50 PM - edited 04-05-2014 04:04 PM
@TC,
you missed the 3 second delay- don't sweat it too much! but, there is a HUGE difference between sample clocks and samples acquired I really do recommend reading the help file it is fairly pointed on what the function does and when it is potentially useful....
Beyond those limited use cases...... it really depends on what the hardware supports if the function COULD return "Is Late?" = True. I jumped in "Splashing!" on the thread because it went down the wrong road. Someone BLUE Should have beaten me to the punch and asked about the hardware attached. Yet, the OP was so offended by expected bahavior and ....
For what it is worth- I learn a LOT from my mistakes too... Many of those mistakes are availablefor public viewing on these forums.
04-05-2014 07:26 PM
Thanks Jeff- this one is a bit of a mare as I can't run it!
04-05-2014 11:13 PM
04-14-2014 01:39 PM
Do you ever crack this one, hookso? I'm interested in the answer if so.
04-15-2014 12:24 PM
