03-06-2006 04:46 AM
Epictetus
03-07-2006 07:19 AM
Hi TiTou,
I can reproduce this behaviour on my PC. But I´m quit happy that it is not the other way around.
It seems that this is a known behaviour in older LabVIEW-Version. This also occurs with other Property Nodes, not especially DAQmx-Nodes.
Best Regards
Alex
NI Switzerland
03-07-2006 08:08 AM
Epictetus
03-07-2006 08:36 AM
Hi TiTou,
first of all, I don´t know a fix to dissable this behaviour. But the Point is, you can undo everything until you change the Property Node Attribute. After you change the attributes you can go back with undo, but only to the last attribute change you made.
I´m sorry for this behaviour, but as you can see it´s fixed in LV 8.
Alex
NI Switzerland
03-07-2006 08:39 AM
Epictetus
