DAQmx multichannel read error. DAQmx believes there are multiple channels in my task.
I recieve the appended error message when attempting to use DAQmx Read in my VI.  LabVIEW is telling me that I am attempting to read a single channel when my task is configured for multiple channels.  However, as you can see in the task configuration pane, that is not the case!  If I attempt to use DAQmx Read to generate a waveform with multiple channels, the VI executes without error but I do not want a 1D waveform array..  Any tips?
Steve
Message 1 of 8
(2,845 Views)
Ok, but what does the code look like? Just because you defines a task, it doesn't mean you are using it.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(2,818 Views)
Mike,
The relevent code in the block diagram is pictured adjacent to the error popup window.
Steve
Message 3 of 8
(2,803 Views)
Your first picture show you are using a task called Vin (although only the V shows up on your block diagram.)  Your second picture shows a DAQ assistant with a single channel.  That has nothing to do with the first picture.
You need to show your picture in MAX that shows the definition of the Vin task.
Message 4 of 8
(2,796 Views)
Here is the task as it shows up in MAX, Identical to the second picture shown before when selecting "Edit NI-DAQmx task" from the task on the block diagram.
-Steve
Message 5 of 8
(2,782 Views)
Accepted by topic author kodex1717
Without seeing the whole code I can only offer a possibility.
Something else in your code is modifying the Vin task and leaving the reference open.  Vin then exists in memory with multiple channels but those changes are not saved to MAX meaning when this section of code executes the Task is not the same as the Task in MAX.  Slap a DAQmx Task node on there and read "Channels" to confirm my suspicion
"Should be" isn't "Is" -Jay
Message 6 of 8
(2,761 Views)
Jeff,
You were correct.  In troubleshooting the problem I had played with the task at a different point in the program and added an erroneous channel.  Thank you!
Message 7 of 8
(2,741 Views)
This is exactly why I ALLWAYS hide my DAQ Tasks inside a "Resource Module"
As I use the term a "Resource Module" is a special case Action Engine tha exposes only that subset of functionality that a specific project needs to take on a given resource external to LabVIEW.  And, it provides a single point of entry to access that resource by keeping private data private.  Had you used the technique here you would have had one vi to look at.  and, there likely would have been no "Reconfigure to add channel" method available to cause trouble.Smiley Wink
Message 8 of 8
(2,721 Views)
