Reply
DAQmx function blocks missing from Labview palette
I have just finished installing labview 2012 development suite to my current computer including NI-DAQmx 9.4. I have done this in the past and had no problems, this time however when I open LV the DAQmx function blocks are not available to me despite everything else being there and functioning correctly including the Measurement and automation software.
I have gone through and checked to make sure that I included all components of the software and its drivers. Is there anything that I may have overlooked while doing this install that would cause the DAQmx blocks to be unavailable to me.
Thanks.
(906 Views)
Re: DAQmx function blocks missing from Labview palette
Did you install DAQmx before or after LabVIEW?  If you installed before, you need to reinstall DAQmx.  It won't take long.  It just needs to add the LabVIEW support.
The discussions from the Advanced User Track is not over. Join in the conversation: 2016 Advanced Users Track
(897 Views)
Why would you install NI-DAQmx 9.4 with LabVIEW 12.
According to NI-DAQ and LabVIEW Version Compatibility (for Windows) you need NI-DAQmx 9.5.5 or higher.
(877 Views)
