Hi, guys!
I am a freshman.
I have a trouble with DAQmx channel configuration. I have two channel to configure ,one need IEPE ,and another one not , but in the example ,I have to configure both of them to be IEPE stage or not .
And the help context tell me I have to use the DAQmx API to specify the desired configuration .The question is I don't know how to do it .
If you have any suggestion or example, I would be appreciate.
You can find the example with the guide of the following picture .
Thx !
lease Mark the solution as accepted if your problem is solved and help author by clicking on Star kudoes.
