10-10-2013 03:07 PM
I really need a quick help or adivse. I am using DAQmx.vi API for my programming and I created a DAQmx Task consisting of 12 channels (ai0:ai11). I want to extract a subset of these channels (ai04:ai011), and also combine channels ai4:ai8 into one channel/signal, and plot on a waveform chart. Also, I want to plot the remaining signals ai0:ai03 on a separate waveform. How can I achieve that? I tried using the Split Signal Functions, Merge Function, and COmpound Arithmetic, but to no success. I splitted the original task using the "split function", but when I try to wire up the signals into the "compound arithmetic" function, LabVIEW tells me that am wiring up two different datatypes. I need a QUICK HELP, anyone, PLEASE!
10-10-2013 09:46 PM
Read signal out as 2D array and use array function to achieve it.
