08-29-2014 12:57 AM
08-29-2014 01:06 AM
that my front panel when I run this vi. remains like this.
08-29-2014 01:20 AM
08-29-2014 01:36 AM
error wires? you mean the yellow one? I wired this but it shows no error.
With daq assistance it can get resonable values and I set it to continuous samples, 1 sample to read, 1 Hz Rate. RSE
and for DAQmx I set to RSE.
08-29-2014 01:41 AM
Hi Ame,
you missed an important point: Configure once, use often, close once!
In your loop you create an I/P DAQmxTask in each iteration without closing it. This will fail in the 2nd iteration…
Go through the DAQmx example VIs coming with LabVIEW. They explain how to configure such basic measurements!
08-29-2014 02:07 AM
08-29-2014 06:51 AM
Why do you keep creating different threads for the same issue? As I told you before, mimic EXACTLY what I did with the output with the input. The only difference is you need to configure the channel as an AI voltage and use the DAQmx Read. But the setup and the closing of the task should be EXACTLY the same.
