12-19-2006 05:52 PM
12-19-2006 11:00 PM
12-20-2006 08:10 AM
Thanks Dev, that confirms what I thought.
Your idea about two different lines (one to write, one to read) would not work for my purpose, since I want to read the exact line that I have set high (or low). That would work if I wired one line to the other (physically) but I can't do that. Looks like I'm going to have to rely on (physical) LED's to check the status if I want to leave the line as a Write.
12-20-2006 09:27 AM
Or you can simply program the DO task yourself instead of using the DAQ Assistant. Personally, I'm of the opinion that if you're allowed at least a half hour to program your application, you shouldn't even consider the DAQ Assistant. The forums are littered with all kinds issues people have due to the somewhat hidden limitations of the DAQ Assistant and Express VI's.
If you create a DAQmx DO task from scratch by following one of the shipping examples, you will be able to insert a DAQmx Read call to read back the state you are presently outputting. With DO tasks, you can both Write and Read the output bit.
-Kevin P.
