DAQmx Documentation Bug (Pascals value)
The Ring Constant value for Pascals is documented as 15881 - it is actually 10081.
Example:
DAQmx Create Virtual Channel.vi, AI Pressure Bridge (Table Scale) instance
steve
Help the forum when you get help. Click the "Solution?" icon on the reply that answers your
question. Give "Kudos" to replies that help.
(2,769 Views)
Nice catch.
"Should be" isn't "Is" -Jay
(2,726 Views)
Thanks for pointing that out. I'll make a note of it so we can correct that.
Eden K
(2,698 Views)
