12-03-2015 11:19 AM
Hello ,
I have pressure sensor from PCB , model number is 113B27 which is ICP make.
I am using NI 9218 universal analog input module on compact DAQ to measure pressure.
I use DAQmx Create Task.vi, then DAQmx Create Scale and then DAQmx Create Channel.
DAQmx Create Channel is a polymorphic VI which accepts Analog Input of type current, voltage, resistance, torque etc etc..
My porblem is that I do not see pressure IEPE type in that polymorphic selection. Only Force IEPE is there and Velocity IEPE is there.
What should I choose to connect my PCB make ICP pressure sensor. Should I use Analog Input Sound Pressure?
Please let me know. Also my pressure sensor specification is for +/- 5 V for 100 psi and sensitivity is 50mV/psi.
Thank you
12-11-2015 01:54 PM
Hello Hemagopal,
First of all, you have to verify if the sensor 113B27 is of type brigde. You can not use Analog Input Sound Pressure because it is for a small scale. In the case of
"Force" you only have three options Bridge (Two-Point Linear Scale), Bridge (Table Scale) and Bridge (Polynomial Scale). So, you have to locate which category belongs your sensor.
Lis Villanueva.
