DAQmx Channels To Read Property Not Working
I have an AI task configured with multiple channels and then set the Channels To Read property to the channel I want before calling the Read VI. If the Channels To Read property value that I set matches the value that was previously set the task passes all the channels to the Read VI rather than the single channel of the property. Does anyone have insight into what might be the problem?
(2,481 Views)
Hi LabTech,
What versions of LabVIEW and DAQmx are you using?  Can you include a screen shot of your code as well?  All of this information will be helpful for attempting to replicate this behavior.
h_baker
(2,454 Views)
Hi, I'm using Labview 8.2 and DAQmx 8.8. I have attached screenshots of the code.
(2,441 Views)
