DAQmx Channel (AI min/max) read
System:
LV 2012,  DAQmx 9.7.5 on PXI-8110
I have about 30 DAQmx channels (mostly Analog Inputs) with custom scales on my RT (8110) running LV 2012.  When I programatically read AI.Mx & Min using LV 2012, It get bogus (non zero) values for the first 15 channels and then the rest have correct values.
Is this a bug or am I doing something wrong?
(2,306 Views)
The 8110 is a controller and not a DAQ card and the ai min and max for a daq card channel is not supposed to be zero. The values are the range for the A/D - +/- 5 volts for example.
(2,301 Views)
