07-14-2010 11:39 AM
Hello again, this is most likely a simple question with an obvious answer however I have yet to figure it out. I have some code working, two AO essentially. The outputs are custom waveforms. I want to set the value of the waveform to zero at the start of each run regardless of its value at the start of the program, in other words I want to have each start be at the same 'location' on the waveform, in this case the bottom. Is there a simple way to do this? By default the program picks up at the last value position.
07-14-2010 12:45 PM
Attach your code so that we can see what you are doing.
