01-25-2014 10:57 AM
My DAQ devices are visible in NI-MAX 5.5.1 and operate correctly. They also work in LabView Signal Express 2012. However, when I installed LabView 2013 and tried to use them, they don't show up in the Measurement IO so I can't acquire any data. I have a Windows 7 64-bit computer with NI-DAQmx 9.7.5 and NI-VISA 5.4 installed.
Why do the DAQ devices work in NI-MAX and LabView Signal Express but not in LabView?
01-25-2014 11:18 AM
01-25-2014 11:58 AM
I did a repair but didn't actually re-install. I'll download the latest NI-DAQmx 9.8 and install that to see what happens.
01-25-2014 01:44 PM
Actually I downloaded and reinstalled NI-DAQmx 9.7.5 and LabView is working now. Thanks.
03-20-2015 03:05 AM
I got a problem in NYP that this computer can't get any DAQ assistant how to acquire signals or generate signals. Can help?
03-23-2015 01:04 PM
Hi aloislowintown,
I think it would be best to post your question to a new thread, since this thread is more than a year old. Also, please specify what NYP is. Thanks!
03-29-2015 07:49 PM
Nanyang Polytechnic
Can you help me to connect the temperature and humidity control?
03-30-2015 10:56 AM
Hi aloislowintown,
You can find examples on how to acquire data from a DAQ device in Labview by going to the 'Help' tab, and choosing the Find Examples option, in there you should go to "Hardware Input and Output->DAQmx", there you'll find multiple examples on how to this.
Also as jMunny previously pointed out, it would be better to create a new thread since this one is pretty old, and the original issue is already resolved.
