10-17-2014 11:28 PM
10-18-2014 12:27 AM
When you can see it in MAX, just check the same configuration which shows the data successfully. Then create a Task in MAX itself whith the similar configuration and then use that task in LabVIEW to perform the same thing what you did in MAX. Explore the LabVIEW examples for data acquisition, you may have to check continous data acquisition examples for your experiment. Once this is successfull you can then proceed with the low level configuration of Channels and acquisition in LabVIEW.
10-18-2014 01:03 AM
10-18-2014 09:19 PM
Thank you both. I will give more detailed informaiton when I have access to the hardware on Monday.
10-20-2014 02:57 PM
The DAQ card is a "PCI MIO 16E-1" card, which from the data sheet, also looks like it might be called the "NI 6070E"
10-20-2014 03:12 PM
10-21-2014 08:02 PM
Its interesting that MAX recognizes it then. I believe I am running a 32bit version of Windows XP. Is there a way to spesify the traditional driver? I'm new to LabView, and the DAW Assistant was the only means of interfacing with the device I could come up with.
10-21-2014 08:34 PM
10-22-2014 01:43 PM
Hello teroenza
I don’t know which version of the DAQmx driver are you using, you can check for compatibility on the readme file for the corresponding version. I apologize if I misunderstood which device are you working with, but, in the case of the PCI MIO 16E-1, it looks like it should be compatible with DAQmx 14.0, as you can check on the next link
http://download.ni.com/support/softlib//multifunction_daq/nidaqmx/14.0/f1/readme.html
There might be confusion, since the NI 6070E is listed as only compatible on the PXI version, but under the name of NI PCI-MIO-16E-1 it appears as compatible with the driver. If someone thinks that I am making a mistake, please let me know, the information for this particular device on the readme file of the driver seems to be a little confusing for me. If MAX recognizes the device, I would go ahead and try the suggestions from P@Anand.
Wen R
10-23-2014 01:36 AM
I will try the above solutions, or find a work-around. Thank you.
