11-02-2005 12:14 PM
11-03-2005 08:55 PM - edited 11-03-2005 08:55 PM
Hi Martin,
To generate a finite number of iterations of a buffer in DAQmx you set the "sampler per channel" property of the DAQmx Timing VI to your (number of iterations) X (number of samples per channel in the buffer).
I'm excited that you are converting your code, the DAQmx driver is so much easier to use. Here are some great references about converting from Traditional DAQ to DAQmx:
Message Edited by Micaela N on 11-03-2005 08:55 PM
11-04-2005 07:27 AM
11-08-2005 08:21 AM
