11-20-2012 10:53 AM
We are knew to Labview but we have been given a Labview program that previosuly worked. The program sends signals to resistors to turn them on and off to measure a voltage of a power supply.
We keep getting this error when we try to run the programm, is the issue with our program or with the circuit?
Thank you
11-20-2012 11:01 AM
What is your timeout? How many samples are you trying to collect? What is the sampling rate? Can you just post the VI itself?
And for future reference, post images as jpg or png. There are many people who don't want to open up Word documents.
11-20-2012 11:04 AM
Are you by chance using a USB DAQ on Windows 7? Was the machine that it was previously working on XP? Check out this KB from NI. You'll have to update DAQmx to 9.4 and set the property node mentioned in this post.
http://digital.ni.com/public.nsf/allkb/611475F9BE62881E86256FDC0062B1BB
11-22-2012 04:46 AM
The time out is 30 seconds.
We are trying to collect 14 samples. I'm not sure what the sampling rate is?
Is one of these attachments the VI?
Thank you
11-22-2012 04:57 AM
Hi Charles,
We are running on Windows XP. The macine has always been working on XP.
Do you think it could be a problem with one of the USB DAQ leads?
Thank you
12-13-2012 09:38 AM
Hi
Have you managed to find a solution to this problem? If not then you may find the following link useful:
Why Do I Get Error -200284 from my DAQmx Read VI?
Kind Regards
