02-06-2014 10:16 AM - edited 02-06-2014 10:17 AM
I am trying to communicate with a cDAQ, but just recently I go to place a DAQ assistant on my block diagram and it sits there and does nothing. I cannot change any of its properties. I am running LV2013, and have been using this computer and install for about 6 months without problems. I am not missing any critical updates. Does anybody have any ideas as to what the problem is? a screenshot is attached of what the DAQ looks like after I place it.
Jake
02-06-2014 10:42 AM
What version of DAQmx do you have installed? Did you install DAQmx AFTER installing LabVIEW? What happens if you double-click the DAQ Assistant?
02-06-2014 01:03 PM - edited 02-06-2014 01:04 PM
Was just going to say the same, I had this issue because I installed DAQmx first. Had to uninstall and do again, but if you say you've had it installed for the last 6 months and you have used it in that time, maybe check your licence agreement/expiry.
02-06-2014 01:55 PM - edited 02-06-2014 01:56 PM
How do I check my license agrrement/expiry?
DAQmx is version 9.7.5f1
nothing happens when I double click on it.
I do not remember what order I installed them in, it should have been after labview though.
02-06-2014 02:46 PM
Just to be safe, I would reinstall DAQmx. It might just be missing the LabVIEW support. No need to uninstall just yet.
07-30-2015 02:37 AM
How can I launch DAQ Assistant even if I don't have a DAQ card installed yet in my PC? I have to create a program on a separate PC without DAQ then run it later on a PC with functional DAQ system.
07-30-2015 03:00 AM
