07-14-2015 08:45 AM
Hi all,
I have LabVIEW 2013 installed, and in all the tutorials it says that the DAQ assistant should launch once it is dropped onto the Block Diagram. I have been doing so (Express > Input > DAQ Assistant on the Functions palette) but nothing launches when I put it on the diagram.
Why is this happening? Are there any solutions?
07-14-2015 08:51 AM - edited 07-14-2015 08:52 AM
The default setting in LabVIEW is to configure when dropped, but this box can be unchecked. Double-click to configure if it doesn't automatically show the popup.
To change the setting go to Tools > Options > Block Diagram tab > "Configure Express VIs Immediately"
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
07-14-2015 08:59 AM
Hi James,
I have tried double clicking it, and nothing is happening. Do you know why this is?
07-14-2015 09:00 AM
07-14-2015 09:04 AM
I installed DAQmx version 14.0
07-14-2015 09:08 AM
07-14-2015 09:12 AM
Yup, sounds like a bad install 😕
Cheers
