DAQ Assistant doesn't appear on Labview 2013 for cDAQ 9174
I installed the driver from the following link http://www.ni.com/download/ni-xnet-14.1/4947/en/ for cDAQ 9174, but in Labview the DAQ Asssitant block won't appear, do you know what it can be?
(2,914 Views)
That driver had nothing to do with DAQ. You would want DAQmx.
http://www.ni.com/download/ni-daqmx-14.1/4953/en/
(2,903 Views)
Thanks for the information, so what is the link I provided for since it's in the support page of the cDaq 9174
(2,890 Views)
Like it says on the page - NI-XNET. You would use that for a CAN card in your chassis. What modules are you using? The chassis isn't much good without some modules.
(2,885 Views)
It seems that the support page for that chassis has a big error in it.
The hardware drivers listed is not correct. Somehow the XNET version 14 drivers has been listed instead of the DAQmx driver.
Currently I have option to write a mail to NI webmaster, hope that a NI AE is seeing this post.
(2,866 Views)
Well, it does list DAQmx, just not the latest that was released in August.
(2,856 Views)
