Custom scaling
Hello, im new with labview and have a small question (i hope) for custom scales.
attached is an example from me but the scale doesn´t work. the connected devise is a simulated is a simulated usb 6000. in my opinion i created a factor of 100, and a voltage range of 0-10V. but i don´t get scaled values.
i´m knowing that i can create scaled tasks in automation explorer but i want to understand the manual way.
thank you very much in advance
(2,444 Views)
Simulated devices return a sine wave that oscillates between the channel min and max values.  Scaling doesn't work with simulated devices.
Edit: Here is a link to a tutorial on simulated devices.
aputman
Heads up! NI has moved LabVIEW to a mandatory SaaS subscription policy, along with a big price increase. Make your voice heard.
(2,432 Views)
You don't need the custom scale name property node although it can be done that way.  The scale can be wired right into the Create Channel VI.
aputman
(2,398 Views)
