05-22-2014 03:07 PM
I want to have Hourglass shaped custom indicator, so that if we give numeric values from 0 to 100, the (sand or water) should fall from top to bottom of glass. waiting for your kind help.
Thanks.
05-22-2014 03:20 PM
This thread has a lot of useful information and a few examples on rotating a picture in a 2D picture control.
http://forums.ni.com/t5/LabVIEW/How-to-rotate-objects-or-pictures-on-my-FP/td-p/196148/page/3
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
05-22-2014 03:30 PM
Thanks for the reply,
Not exactly, what i am look for. I need some nice way to indicate the user that "How much time elapsed for the particular process". We are thinking it show it in the form of Hourglass.
05-22-2014 03:32 PM - edited 05-22-2014 03:40 PM
In addition to that, I dont want to rotate the hourglass. Sand should flow from top to buttom of the indicator, no rotation of hour glass is needed.
05-22-2014 03:35 PM
You would call this code in a loop, and update it with the new position based on how much time has elapsed.
05-22-2014 03:37 PM - edited 05-22-2014 03:39 PM
I don't know a whole lot about graphics, but you could take the Sprites approach. (From video games/simple animation). Much like a flip-book you may have made as a kid, have a set of pictures for each portion of the hourglass being full/empty. Then simply iterate/display through these images at a smooth frame rate.
I've never done this in LabVIEW, but this is how much 2D is done on mobile devices (something I have a bit more experience with). I'm sure the methodology could be applied in LabVIEW as well.
05-22-2014 03:42 PM
This isn't all that bad of an idea because LabVIEW has a Picture Ring, where you load N pictures into a ring and then give it a value to display each image one at a time.
05-22-2014 03:53 PM
It means that i should have 100 images of different positions of sand. It is tedious task. I was looking for custom designed hour glass indicator in labview. But now, based on your idea, i have something to start. Let me try this... Thanks for the reply.
05-22-2014 03:56 PM - edited 05-22-2014 03:56 PM
Well you don't need 100, what about 10? or 20? is that enough movement for the user to see progress? You don't need one new picure for each degree is what I'm tryin gto say. If not the original post I had lets you rotate down to something like 0.01 degrees or less.
05-22-2014 04:36 PM
No 100% what you're asking for, but if you make part of your image transparent and place the approprite indicator behind your picture, you can get what you want. I played with the transparency alph channel in a png here... and did NOT take my time to make it pretty.
