Reply
Ctrl+= "make font size larger" keyboard shortcut is not working, maybe related to Windows 7?
I changed recently from Windows XP to Windows 7 64bit, and since then the keyboard shortcut Ctrl+= to make "font size larger" is not working anymore. Ctrl+- to make "font size smaller" is working like always. I tried this with LV8.5 and LV2011 and the missing functionality is on both LV-versions. So I wonder if this is related to Windows 7... Or am I missing something?
Any ideas?
I tried to switch keyboard input language without success. Then searched for menu shortcuts in the LV options, where Ctrl+= is not listed as it is only a keyboard shortcut and not in the menu. I wonder also why the whole font setting is so nestled in LV, why not just having a toolbar...
Looking forward for any help.
(3,208 Views)
Re: Ctrl+= "make font size larger" keyboard shortcut is not working, maybe related to Windows 7?
It works for me. I'm using Windows 7 64-bit, but I'm running LabVIEW 8.2, so I can't test this on other versions. Are you sure you don't have some extension installed that's using that keyboard shortcut?
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/A-text-toolbar/idi-p/953534
(3,191 Views)
It works fine in 2011 on Win7, 32-bit.
(3,182 Views)
Thanks for checking it on your systems. Thanks
I try to find what extension could interfer with the LV keyboard shortcut. I have running LV8.5 on Windows 7 64bit, and LV2011 32bit inside a Virtual Machine from Virtual Box running also Windows 7 64bit.
(3,167 Views)
its the same problem with me...
lv2012 32bit and 64 bit
Kudos always welcome for helpful posts Smiley Happy
(2,757 Views)
