Hello wally424,
It is quite normal for the cross correlation to be in the tens of thousands. Two methods of normalization are given in the following link:
Cross Correlation NormalizationYou should be ending up with only about 400 data points on the x-axis. You mentioned yours is in the thousands; exactly how many are you getting?
If none of these suggestions help, or if I�m not correctly understanding your issue, please post the software and versions you are using, the applicable portions of your code, and any other information that may help, and I�ll be happy to look further into it.
Have a ni
ce day!
Robert M
Robert Mortensen
Software Engineer
