There are many examples for how to use VIs in the example finder (Help>>Find Example). You can also find information in this site. The problem is that what you wish to accomplish is not the easiest thing. You will need to do some graphic manipulation to get a good user interface. You will need to learn a bit about events.
To learn more, I suggest you read the LabVIEW user manual. Also, try searching this site and google for LabVIEW tutorials.
Here and
here are a couple you can start with. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read
the LabVIEW style guide.
___________________
Try to take over the world!
