11-04-2011 09:40 AM
I found them while poking around with scripting.
Haven't found much else particularly interesting except for some decorations.
The file "Decos.vi" has the interesting decorations.
The file "Object_Style_Ring.ctl" has the codes for all of the objects I've found.
11-07-2011 10:40 AM - edited 11-07-2011 10:42 AM
Nice!
You should post an Idea on the Idea Exchange to include the pipes (controls and decorations) as part of the normal palette setup.
11-09-2011 10:03 AM
As I mentioned in an earlier post in this thread, atttached is an example of an illuminated flowpath using decorations, and also uses the UID scripting property node, as mentioned in this Micro-Nugget . It uses the pipes as mentioned above.
You need LV 2011.
11-10-2011 08:44 AM
I have been informed that my VI above is password protected. The password is "starbucks" without the quotes. Sorry about that!
01-21-2012 08:16 AM
The multi-segment pipe is bugged.
If you set its value with the value property node, the state will be reversed.
Try it.
01-23-2012 07:58 AM
Try it.
Please post a sample to illustrate.
Ben
01-23-2012 09:02 AM
Hello.
Try this VI to see this ugly bug
01-23-2012 09:33 AM
When I work with the pipes I seldon use them as booleans but rather drive the colors using the colros property nodes, so...
WHat exactly does not seem right to you?
Ben
01-23-2012 09:37 AM
grey = false
blue = true
but in mith multi-segment pipe + property node, we have grey=false then grey=true then blue = false
try my VI to see that
I don't care about the colors, my purpose is about the link beetween color and associated value.
02-01-2016 06:44 PM
Just an FYI that the bug SebastienM found with writing the value of a Multi-Segment Pipe indicator still exists in LabVIEW 2015 and the associated DSC module. Just ran across it today. Adding special code to work around this bug by inverting the value before writing it to Multi-Segment Pipe indicators via a property node.
Perhaps NI is leary of fixing this bug for fear of breaking code that has this type of workaround.
Hans
