Creating an equispaced 1D array
Other than using a for loop, is there a quick way (or trick) of creating an equispaced array of numbers with min, max and number of points / spacing specified ? A bit like the Matlab linspace function.
Given max = 10, min = 9, and spacing = 0.1, get 9,9.1,9.2,9.3,..., 10.
(3,068 Views)
Look at Ramp Pattern.vi under Signal Processing >>  Signal Generation palette.
(3,059 Views)
In this thread I show one way to do it without using a loop.
http://forums.ni.com/t5/LabVIEW/Creating-an-array-when-you-have-the-first-and-last-element-and/m-p/1...
In LV10 you can use the Ramp.vi and select Ramp by Delta.  If you peek under the hood, you may be disappointed to discover a For Loop.
In the old days, LV was very slow when it came to loops and I often had to resort to external code (CINs) to generate even modest integer arrays.  These days things are much better, so I don't fully understand the aversion to loops.  Smiley Wink
(3,054 Views)
