07-27-2015 04:18 PM
Hello All,
Is it possible to set up an event case to occur on a right-click down when the cursor is over an image? If so, please post details.
Thanks!
Solved! Go to Solution.
07-27-2015 04:49 PM
Yes, I think the event case for Mouse Down has a property (I think it is actually called the data node, but it is the drop down that appears on the left side of the event case) called Button which tells you which button was pressed. Also, you can get the mouse coordinates from the event case data node and calculate whether or not the mouse was within the picture frame. Hope this helps. I don't have Labview, right now, so I can't create an example.
07-27-2015 07:21 PM
Good luck!
07-28-2015 12:37 AM
07-28-2015 02:12 PM
Thanks to both of you! The posted VI solved my problem.
