As part of an independent study I was asked to try and create or modify a VI to monitor a torsion transducer. The signal is a triangle signal, which looks like this /\/\/\/\, and measures from 0 to 60 degrees then the signal goes negative for the next 60 degrees and so forth. Since we need to rotate 360 degree, I am having problems with properly measuring the signal. I do not know how to modify the VI to accommodate for when the signal goes negative. The professor that I am working with is not proficient in LabView either, and has been unable to assist me. Any help will be greatly appreciated?
