Creating Spaced array in Labview
I have a question regarding "creating a spaced array" in LabView using this following math script.
Dt=diff(t1);
dt=mean(Dt);
tStart = min(t1(1),t2(1));
tEnd = max(t1(end),t2(end));
tEqui = (tStart:dt:tEnd)'
 where, t1 And t2 are timestamps from labview.
Thanks in advance.
(2,779 Views)
Look for the ramp function.
GCentral
(2,771 Views)
Is this the way to do?
Akash
(2,738 Views)
I don't think you need that FOR loop around the Ramp Function.  You could also replace some of that Math Script with real LabVIEW code to get some performance boost.
GCentral
(2,710 Views)
hey,
can I know which array function you used in that code?
I couldn't find it.
and I have attached the m-file of the project I am working on trying to convert the Matlab code to labview but getting errors as I am analyzing dynamic data.
so any way you could just give pointers about these functions from m-file in converting into labview code:
 ind_nonunique=find(diff(time)==0)+1;
nFFT = 2^nextpow2(2*n-1);
Xc = real(ifft(X.*conj(Y)));
Akash
(2,700 Views)
Which one?  I have Delete From Array, Array Max & Min, Build Array (which is resizable), Derivative x(t).vi, and Ramp Pattern.vi.
GCentral
(2,674 Views)
yes I figured it out. it was delete from array function.
Akash.
(2,669 Views)
