01-28-2013 09:15 AM
You are on the right track. When I asked about hte IMAQ VIs I meant the initial ones that generated the initial file. Those are the ones that are un-needed. See the VI I attached (downconverted to 2011).
Starting with an empty picture (white background by default) I draw my black rectangle. I then convert it into an image that is 500x500. Finally, I save the image as a png.
Mike...
01-28-2013 10:13 AM
Thankyou mike!!
Yes now i get it what u meant about IMAQ..
Thanks alot!!
01-28-2013 10:18 AM
You're welcome - and thanks for the kudos.
Mike...
