I am making one of my first attempts and creating LabVIEW project templates and would like to create some empty folders in the project for content that the user (me) will generate when writing code later. I can't see how to do that, and am wondering if it is possible. I tried adding the empty folders to the project template, but when I create a project from the template, the folders show in the Items tab of Project Explorer, but are not created on disk. If the folders have files in them (they are not empty) and are included in the project, then they are created on disk when the project is created. Is there some way to create empty folders on disk using a project template?
You'll need to add an "AfterPage2NoUI" custom scripting VI that creates the empty folders on disk after the user project is created. I'm assuming you've already seen this document, which talks about creating custom templates/sample projects. The use of an AfterPage2NoUI VI is covered in this document. Let me know if you have any additional questions.
