Create a 2D array with random numbers
Yup, my head is in the toilet, i leave for France in 3 hours.  Here, this should be the right one.
Message 11 of 16
(3,307 Views)
hello, i am very interested in your .vi because me too i want to create a 2d array with random values. please can you reattach your correct .vi ??
 there is an error with your last file...
Message 12 of 16
(2,411 Views)
this post is 5 years old .. please let those old post sleep, unless you have something substantial to contribute .. and btw there is nothing wrong with the vi
here is a snippet, from that you should be able to do it yourself
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 13 of 16
(2,400 Views)
thank you
Message 14 of 16
(2,389 Views)
You need to be much more specific. The above answer will give you equally distributed random values in the range 0..1 This is usually not very suitable for physical problems.
If you for example want to add random noise to a 2D array, you should use this function with the number of samples as the product of the dimensions, then reshape to the desired 2D array at the end. See how far you get.
Message 15 of 16
(2,374 Views)
Yes, there is (at least with the VI name)! 😄 When using chrome on windows 10, it cannot be downloaded (network error).. Same for the VI in the first posts. My guess is that there are certain characters in the file name that confuse the browser and mess up the URL. I have notified the moderator, maybe they can be renamed.
Message 16 of 16
(2,373 Views)
