Create a 2D array with random numbers
So i am able to create a 5x10 2D array with random numbers.  however im trying to figure out how to assign each row a giveen value range.
such as:
Row 1: 0-1
Row 2: 1-0
Row 10: 9-10
Can someone give me a hint on how to acomplish this task.
Message 1 of 16
(13,122 Views)
Homework time at uconn? 😄
Put the dice in the inner loop. Then, in the outer loop, add [i] to the 1D array. See how far you get.
Message 2 of 16
(13,120 Views)
I tried putting multiple loops on the inside and adding one to the first and two to the second but then I couldnt get it to display in an array.
Message 3 of 16
(13,118 Views)
I don't understand a word what that all means. LabVIEW is graphical, so show us a picture instead!
(How many are "multiple"? inside of what? first of what? second of what? get what to display?)
Message 4 of 16
(13,115 Views)
Am i going in the right direction.  I have read my text book and looked at the examples but i am really strugeling with the arrays.  I have posted what i have so far.
Message 5 of 16
(13,105 Views)
I'll give you a hint, since this is homework, so I'm not giving you the answer. What happens if you wire a value out of a loop with autoindexing turned on? Do you get a number or an array? What happens if you put another loop around that, so the output from the first loop goes through another autoindexing operation? Do you get a number, or an array? If it's an array, is it the same type of array, or different?
Message 6 of 16
(13,103 Views)
I'll give you a hint, since this is homework, so I'm not giving you the answer. What happens if you wire a value out of a loop with autoindexing turned on? Do you get a number or an array?(You get an array) What happens if you put another loop around that, so the output from the first loop goes through another autoindexing operation? Do you get a number, or an array? If it's an array, is it the same type of array, or different? Different
Im sorry to be a pain, but i am still not grasping all the elaments that are going into this problem.
Message 7 of 16
(13,097 Views)
Try again to read my very first reply:
What could I have possibly meant with [i]? Is there something in the outer loop that would fit that description? 😮
Message 8 of 16
(13,090 Views)
WOW!  I feel like a true idiot, ithought it was adding 1.  I didnt pay close enough attention to [i].  I am so sorry for wasting your time.
Message 9 of 16
(13,084 Views)
I think you attached the wrong VI.
Message 10 of 16
(13,078 Views)
