Create Unit Test Vectors From The Unit Test Configuration Window
I have recently been using more test vectors in the unit test framework.
The principle works well but if you are in a unit test and decide you need a test vector you must:
  • Close the unit test configuration
  • Create a test vector
  • Set up your vector (entering values and data types, which is much easier if you could see the actual unit test case)
  • Close the vector configuration window
  • Open the unit test configuration
  • Assign the new vector file to the unit test
  • Now you can assign vectors to test inputs
This seems convoluted and forces unnecessary context switchs.
I propose that at a minimum, you should be able to create a new vector file and launch it's configuration without leaving the unit test configuration window. I suspect that the whole process could be streamlined even further though.
James Mc
CLA and cRIO Fanatic
My writings on LabVIEW Development are at devs.wiresmithtech.com
(2,427 Views)
Oops supposed to be ideas exchange, sorry!
James Mc
(2,422 Views)
